Anyone know about valve headphone amp fed from a NAC-N 272 - fixed or variable?
Posted by: rjstaines on 26 May 2016
I was thinking of getting a Stax valve energiser (aka headphone amp). I could run it from either the fixed or the variable output on my NAC-N272.
With the solid state STAX energisers you can wind the volume up to max and leave it there, feed it from the variable output of the preamp, sit back and use the 272's remote control (or Naim app) to control the volume in your ears.
However, can the same be done with a valve energiser... is a valve device happy to be left at full volume with the input signal controlling the volume at the headphones, or would running the valve energiser with the volume control at max cause problems (even though the input signal is low) ?
Anybody know about the electronics that's going on with volume control of valve devices ? (like would I blow the valves up or significantly reduce their life span?)
Thanks, Roger
