Nac 32.5 and Chrome Bumper Hi-Cap.......Wow!
Posted by: Lewis on 28 May 2016
Alright fellas.
Ok so I've been chopping and changing my system a bit recently. I still have my UnitiQute 2 and faithful Nap 100 (don't think I will ever part with this duo as it's so convenient and produces amazing sound for the money), but as you probably know i'm really fond of the vintage CB gear and wanted to try a few combo's. Anyway, I think I have found the holy grail of Hi-Fi systems
I was running a Nac 32 for a while with a Snaps and was very impressed with this set up. I then added a Hi-Cap (CB), and while I was always reasonably sceptical about the quality of this 'upgrade', I have to say I was immediately amazed. It sounded as good as adding a new power amp, I just could not believe it. Anyway, that aside, I recently procured a beautiful as new 32.5 so that now sits next to the Hi-Cap. I use the UnitiQute 2 as my main source, as well an LP12 with Lingo Mk1, into some early SBL's, and the Nap 100 providing the grunt. Honestly it reaches remarkably loud volumes with zero distortion and the sound is crystal clear and beautiful.
This leads me on to my question. With regards to connecting the Hi-Cap to the Nap 100 and 32.5; I currently have the link plug in the end socket of the 32.5 which is a five pin din, then the next two sockets which are both four pin go from the 32.5 to the Hi-Cap, then the second to the UQ (tape 2 I use for this). Obviously if I remove the link plug then the LED still illuminates on the 32.5 but no sound is emitted, so therefore it needs this to work. However, how would I use the link plug socket to connect it to the 32.5 as it is this socket that's marked 'Hi-Cap'. So essentially my questions as as follows:
1. Why are there two ways to connect it?
2. Which is best for SQ?
3. What sort of cable do I need to utilise the link plug socket on the 32.5 and thus connect it to the HC (I assume a five pin to five pin DIN but is this a SNAIC?
Thanks gents.
I've posted some images of how it's currently connected:
And a few others to illustrate the beauty of such a combo ![]()
