Is it possible to connect a subwoofer to both XS and AV2 simultaneously?
Posted by: Duncan Hills on 28 May 2016
Hi All,
Seeking your expertise please...
I have recently started building a 5.1 system, and as it stands I now have an AV2 connected to my XS in unity gain mode, and to a v175 for rears and centre. I have an optical connection from my Blu ray player (not sure it's relevant, but for info in case the optical in makes a difference to the answers).
I have a CD5i2 for CD listening and here lies my question:
I have purchased an ASW700 subwoofer which has two line inputs, left and right (no high level). So, I was wondering if it's possible to use one input for the subwoofer out from the av2 for 5.1 listening, and connect one of the two left/right subwoofer outputs from the XS for stereo listening to the other remaining input? Would this work, would it receive both feeds at once, distorting/confusing the output due to timings etc, or would it simply not be possible!!? Or worse, would this cause some sort of damage!
My primary preference is for the 5.1 setup, but if i could have it incorporated to the stereo listening it would just be a bonus. I have b&w 683's which i think do fine for bass, or at least i thought they did until the supplement of the subwoofer. The sub also has two line outs, and two links (for daisy chaining of subs from what i gather)
The subwoofer is potentially just a temporary item, so if you tell me i need high level and low level inputs for this to work, i'd put that into my consideration for future purchases!
Hope that makes sense!
Duncan
