Name MuSo Qb + Naim Unity Qute v1
Posted by: PhilW on 31 May 2016
I just replaced one of my FM radios with a MuSo box. I notice that there's a "multi-room" mode available, and so I updated the firmware on my UnityQute v1 to 3.21 to give it a go.
Qute 3.21 has a new "multiroom" input, which is enabled as per the defaults. The "name" is the default "multiroom".
The MuSo options also have a "multiroom" setting... but I can't work out precisely how I get one to talk to the other. I notice that if I enable "multiroom" on the MuSo, it does the "glowing light" thing, which implies that it's looking for a stream. My Qute is playing at that point, but presumably the MuSo is failing to hear it.
I checked my networking and I can see (ping) each of those Naim devices from other devices on my home network, so there's an ICMP connection there at least. I run the Naim app on a 'droid 'phone and it can clearly see both Naim gadgets, so there's no isolation on the WiFi network preventing the communications. I think this is all not the problem.
So does anyone have a step-by-step "this is how you stream from one Naim device to another" in multi-room mode post they could share? I want to make sure I've set all the correct things for this to work.
