In a 42.5/140, the power supply in the NAP140 has to supply both the power amplifier circuits and the 42.5.
When there is a musical peak, the power amp draws a lot of current to drive the loudspeakers, which in turn creates a ripple in the supply to the 42.5, which then affects the musical signal into the NAP140.
What the hicap does is to provide a much larger and more stable power supply for the 42.5, allowing a higher quality music signal to reach the NAP140.
In summary, it makes a 42/5/140 sound even better. It is a well proven and greatly admired improvement which turns a wonderful amp into a classic. Very much worth doing, so long as funds permit and the hicap has been recently serviced (i.e. within the last 8 years)
Hope this helps Garry.
Best regards, FT
