display not showing tracks available on disc
Posted by: deditionsd on 03 June 2016
Having issues with the display not showing the tracks available but rather stuck at _ _  Need to reopen and close tray on CDX2 a second time. If I load and immediately press play, get an err, then_ _ , then tracks, then need to press play again. Erratic. No answer from Naim. I understand default in dis but not the issue.
Posted on: 03 June 2016 by Finkfan
Hi
Does the disc spin up as soon as you close the tray?
Posted on: 03 June 2016 by deditionsd
It will half of the time spin up to _ _ and then stay stuck there. So far, reopening and closing the tray seems to generally, but not always bring up the track total. Other times it just gets stuck at _ _ again.
Have you tried gently cleaning the laser?
Yes. Both with soft cloth and wiggled the VAM 1202 gently. To expand, had that replaced several months ago as it was skipping. Skipping started again several days ago so have been dealing with that issue with Naim. Might need to have it replaced again as they suggested that it might be "a little picky".  They can't tell me, though, if this display issue is related at all or something else. Skipping has disappeared my last 20 CDs but the display issue has appeared on 9 of those CDs.
Eight years of just load the disc, press play, watch tracks available appear briefly, then it starts playing. Wonderful. Now I have to go through multiple steps, reloads, etc. before I can listen to music. Just annoying but enough to take the anticipation for music down a step.
Hmmm. The other thing to try would be to place the puck back in its position (no cd in place). The puck will stick to the central cd locator. Lift the puck slowly. If the puck lifts the central locator up the motor shaft with it, that could be your problem.
If not, back to Naim she goes.
thanks, tried that, but that is not it. Probably back to service next week. Disappointing.
Shame. The boys and girls will sort it and get you back up and running soon
Posted on: 03 June 2016 by wenger2015
Finkfan posted:
Finkfan, it's not boys and girls, it's umpa lumpas, apparently they are also very good at making chocolate
