Murata Manufacturing Company
Posted by: ken c on 06 June 2016
when i scan my LAN, i get this device appearing with an IP Address of 192.168.08
however when i do arp -a in a DOS window on my PC (attached to same net) this device doesnt appear?
have i got a security problem? or what -- does anyone else get this?
enjoy
ken
This company manufacture wireless network interface. It is one of your network devices. Could be iphone/ipad.
I doubt it's an iPhone or iPad because these always report as Apple on a scan but it will be something that connects wirelessly, like a smart TV or an Internet radio or something like that I expect.
best
Is it on the WLAN?
What wireless security are you using?
Ken - totally normal. Your PC ARP cache used by arp -a command will only contain mac addresses and corresponding IP addresses the PC has talked to within a recent period of time (these do time out). I guess you did your LAN scan on another device or after you ran arp -a on the PC?
If you do a LAN scan by running a suitable app on the PC and then run arp -a you will see all the mac addresses and IP addresses appear - as they will now be in the PC ARP cache as the PC will have just scanned them all. ![]()
Simon
Huge posted:Is it on the WLAN?
WPA Auto... thats the more secure one, right?
enjoy...
ken
Simon-in-Suffolk posted:Ken - totally normal. Your PC ARP cache used by arp -a command will only contain mac addresses and corresponding IP addresses the PC has talked to within a recent period of time (these do time out). I guess you did your LAN scan on another device or after you ran arp -a on the PC?
Simon
thanks Simon, does that mean i haven't been infiltrated? which is my main concern?
enjoy
ken
from the info you have provided I can't see whether you have been infiltrated - but unlikely - and its not really related to the ARP Cache on your PC
If your LAN scan shows devices you recognise then fine - if there are some devices you don't recognise at all - it might be worth hunting them out to satisfy your curiosity.
On Wifi security - yes WPA is preferable. Its WEP you want to really avoid as it is rather easy to hack
Simon
thanks simon -- and everyone else who responded with suggestions.
i have since found out that the device was my Samsung phone -- which i rarely use these days as i have a work one.
enjoy
ken
