mains cable
Posted by: ian collinson on 07 June 2016
what if any do you use with your naim equipment
Posted on: 07 June 2016 by Mike-B
"if any"  ????   must try that next time I play S&G "The Sound of Silence"
I've started with Naim std cables,  then experimented with a few well known 3rd party types & then Naim PowerLine.   For the last 3 years I have my own Supra LoRad fitted with a mix of 13a plugs & IEC sockets - see profile - & I have no wish to change.
Posted on: 07 June 2016 by trickydickie
I tried my system with and without mains cable and found it sounded best with cable in place. I repeated the comparison after I had a dedicated radial supply installed.
The inky blackness was far superior though when the cable was removed
Posted on: 07 June 2016 by Finkfan
I'm a fan of TQ cables. I've got an Ultra blue on my CDX2 and a black on my SN. They're fantastic!
Posted on: 07 June 2016 by hungryhalibut
Mains cables are overrated.
Posted on: 07 June 2016 by wenger2015
Finkfan posted:
I absolutely agree Finkfan,  both superb cables, I'm very jealous
Posted on: 07 June 2016 by Foot tapper
I use grey cables from the consumer unit to the sockets, then black ones from the plugs to the Naim equipment.  They seem to work quite reliably and well.
Posted on: 07 June 2016 by Huge
Hungryhalibut posted:
Really? I find then rather useful... without one the kettle remains resolutely cold, and then tea just doesn't taste the same!
Posted on: 07 June 2016 by Adam Zielinski
I found that when not using the mains cables there was no buzz from the tranformers...
Posted on: 07 June 2016 by Slim68
One for you Ian, it's sort of about mains cables!!
A man has built three houses. Nearby there are gas water and electric plants. The man wishes to connect all three houses to each of the gas, water and electricity supplies.
Unfortunately the pipes and cables must not cross each other. How would you connect each of the 3 houses to each of the gas, water and electricity supplies?
Posted on: 07 June 2016 by CharlieP
Huge posted:
Surely Mr Fish means they are overrated for current or voltage?
Posted on: 07 June 2016 by Emre
so TQs or Powerline?
Posted on: 07 June 2016 by TOBYJUG
Under £1k, Nordost Heimdhal 2 is the best.
Emre posted:
TQs!!
Emre posted:
If uing other Naim cables (interconnects, speaker cables) stick with PowerLines.
Which TQs then?
All Naim systems with all Naim wiring ( speaker cables, interconnects) .... TQ or Powerline? and which TQ? Talking about EU power cables, i don't know if it makes any difference....
Emre posted:
I experimented with a number of different power cables (also in a full Naim system). All EU versions. PowerLine gave it the best balance.
So at the end of the day both of my systems are connected with PowerLines.
Posted on: 07 June 2016 by GraemeH
My current cable is a Hydra.
Posted on: 08 June 2016 by wenger2015
Finkfan posted:
Emre posted:
TQs!!
Definitely TQs and definitely Powerline,  hope this helps...
Posted on: 08 June 2016 by Huge
Slim68 posted:
Carefully and professionally!
Posted on: 08 June 2016 by Knipester
I had a powerline and it was definitely an upgrade over standard but replaced it with a TQ black power and never regretted it.
Finkfan has just taken over ownership of this cable as my new Vitus amp comes with its own Vitus andromeda cable otherwise the TQ black cable wouldn't have been going anywhere.
General rule...
TQ black for power amps
TQ blue for sources or black if you can justify it
Posted on: 08 June 2016 by Emre
 i am currently using JPS Labs cables for pre/power/source, they all different cables, or thats what JPL claiming, i wonder it is going to be an upgrade worth the cost TQ or Powerline my nac272/txps/nap300
Posted on: 08 June 2016 by Finkfan
Knipester posted:
And what a cable the TQ black is Knipester! More detail, more 'air', tighter bass and it really works well with the Ultra blue on my cdp. Can't wait to finish work and have another listen!
Posted on: 08 June 2016 by rjstaines
CharlieP posted:
Huge posted:
Having followed HH for a while, I doubt that's what he meant CharlieP
