Tidal/superuniti; max 500 songs shown and played of playlist.
Posted by: Frits Van Der Veer on 07 June 2016
l.s.
i have on tidal a couple of big playlists (700 and 1300 songs) . Very big if u ask my superuniti. It only shows on the superuniti display that I have 500 songs in the playlist.
Anyone know why this is? It will only play songs out of this 500 songs albeit that the playlist is longer. I would like to see the total songs in the playlist.
Frits
Posted on: 07 June 2016 by ChrisSU
500 is the limit - for playlists or play queues. The workaround is to select them using the remote instead of the app, if I remember correctly, this will queue the whole list.
