Naim Fraim Packaging Help.
Posted by: Tony2011 on 10 June 2016
Is there a safe way of packaging four Fraim  shelves without using the original Naim boxes? Has anyone tried?
Any advice would be most appreciated.
Posted on: 11 June 2016 by Richard Dane
Yes, but it's a bit easier with the original boxes.  Use lots of bubble wrap and lots of cardboard and a big strong (double or better, triple-ply) box.  Oh, and use newspaper, lots of it scrunched up and pack out all the corners, and every nook and cranny so there's no movement inside and plenty of crumple zone. Pack so you feel confident you can sling it down the stairs and all will be fine.
Posted on: 11 June 2016 by Tony2011
Thank you, Richard. I've been told that the  original boxes cost in the region of £60 each and I would need at least two. Being a one-off operation, I thought I would rather try and find a more affordable solution since I am not going to reuse them.
Thank you once again. Your advice is greatly appreciated.
