SL Speaker Cable Plugs
Posted by: sunbeamgls on 14 June 2016
How is it that the sleeves on the plugs become slightly loose - less than 1/8 of a turn?  I find, when cleaning, that I have to check the plug sleeves from time to time to make sure they're still tight.  What's causing them to come loose?  Seems worse at the speaker end than the amp end.
Posted on: 14 June 2016 by Adam Zielinski
I noticed that too. My guess micro-vibrations from the speakers cause the outer shells to sort of 'undo themselves'...
