Roon and Audirvana or Hqplayer
Posted by: T38.45 on 18 June 2016
folks,
some of you are using roon as their frontend - do you have hqplayer or audirvana integrated with roon?
comparing roon native with audirvana i prefer audirvana by miles...
so is hqplayer on same level?
thanks
ralf
Posted on: 06 August 2016 by Code Red
Hi Ralf,
I tried all of them.....and Audirvana is by far the best one I have. I was pretty shocked how artificial HQPlayer as sounding. Tried several options, but no success. So still Audirvana :-)
Best regards
Karl-Heinz
Posted on: 06 August 2016 by Janus
I was switching back and forth between Roon with HQPlayer and Audirvana before - I did not prefer one over another (try different settings, DSD etc.), liking them both a lot. Of course this all changed when I purchased the microRendu and use Roon/HQPlayer which sounds better than anything I have heard before in my setup.
Posted on: 08 August 2016 by T38.45
...thx KH, I still prefer audirvana too----but on the other hand: the usability of roon is simple great...guess I'll stay with roon and live with the SQ impact:-)
