Power supply age (maybe a stupid question)
Posted by: JF Lux on 19 June 2016
Apologies if this is basic  But still new to Naim...Do the power supplies "age" and need any type of servicing ? (I know amps do. And I also know there is the ability to bring some of power supplies to DR spec).
Thanks.
Posted on: 19 June 2016 by Richard Dane
Yes, servicing should be done every 8-10 years on most Power supplies, although 500 series have been quoted at 15 years, so if in doubt, ask naim or your dealer for further guidance.
Posted on: 19 June 2016 by JF Lux
Thanks Richard. And just came back to post that I found the answer......by using "search..."
shouldn't be so lazy
Posted on: 20 June 2016 by Allante93
JF Lux posted:
The only stupid question, is the one that isn't asked!
Mr Richard Dane, has answered your question, but my own personal guideline is:
Amps & PS's -  10 years (+ or -), 2 years depending on usage.
Pre Amp same formula, but 12 years vs 10 years.
However, the real test is your ears, if your system appears a little sluggish, less energetic, perhaps one or the other is due for servicing.
 Allante93!
