Uniti playing up.
Posted by: Geoff W on 23 June 2016
A couple of days ago, my 2012 Series 1 Uniti began switching itself on and off, every 15 seconds or so - a bit disconcerting, I thought.
I tried switching it off and on, which seemed to sort it, but then it continued.
So then, last night I tried a factory reset, which seems to have worked - so far.
So my question is, is the unit paused on the cusp of failing, or do these things happen occasionally? Presumably, iif it starts doing it again it will need sending back, via my dealer?
Posted on: 24 June 2016 by Gavin B
I suspect you're right - a trip home will have it sorted, and hopefully it's something simple.
Posted on: 24 June 2016 by Geoff W
I'd be happier to return it home, if it weren't for all the rumours about long delays, but, que sera, sera. Hopefully that won't be necessary for some time.
