DAC to the Future
Posted by: ellearm on 23 June 2016
My old CD5 regularly fail to play cds , or I have to reload the cd 3-4 times before it start to play.
Nowadays I do not want to buy a cd player but rather buy a DAC . This will be connected to my Oppo 103D for cd playing and Tidal music.
Will Naim DAC v1 give similar sound to my old CD5?
Posted on: 23 June 2016 by analogmusic
yes it will, maybe even better. DAC V1 is fantastic.
Posted on: 23 June 2016 by Adam Meredith
ellearm posted:
This might be relevant - https://forums.naimaudio.com/to...ip---a-doctor-writes
Posted on: 23 June 2016 by Ancient Mariner
I have recently just switched from a CD5/Flatcap, 92/HC/90 system to a DAC-V1, NAP 200.
Although I never compared the two sources in direct comparison. I do feel the DAC-V1 is better.
What I can tell you is my DAC-V1 NAP200 is significantly better than my previous system. I would imagine the DAC-V1 plays a huge part in that.
Ian.
Posted on: 23 June 2016 by SongStream
The DAC-V1 is very capable in my view, seems like a safe bet to me.  Seems most happy with a USB input, which might be relevant if you use Tidal a lot; an alternative digital transport for internet streaming may bring a benefit in the future.  Having said that, there's nothing wrong with the SPDIF route, it still sounds great.
Posted on: 23 June 2016 by ellearm
Adam Meredith posted:
ellearm posted:
Thanks a lot Adam.
Posted on: 29 June 2016 by ellearm
I ordered new puck ( clamp5) .
Adjusting the rubber part on old puck really helped.
About the Dac V1 , I am curious why its output is 4 pin din , my CD5 output is 5 pin din.
Posted on: 29 June 2016 by Richard Dane
I think because it's not really mean't to be a source - it's a DAC/digital headphone amp/pre-amp, hence will most usually be married up with a power amp - hence the DIN4.
Posted on: 29 June 2016 by Eloise
Richard Dane posted:
I'm sure this was discussed before ... but feel its a real shame the DAC-V1 didn't go the whole way and include an analogue input.  Perhaps somewhere down the line we may get a NAC152x-Digital?
Posted on: 29 June 2016 by gary yeowell
No the Dac V1 is not better than a 'working' CD5 with a Flatcap. I have owned the DacV1, and still own a CD5/FC2. They are different, and long term i prefer the CD player, and i also preferred the CD5 to the Chord Hugo.
Posted on: 29 June 2016 by Musicraft (Derby)
analogmusic posted:
Hi AM
+1
All the best
Rick @ Musicraft
Posted on: 29 June 2016 by Hmack
gary yeowell posted:
Do you have a friendly audiologist nearby who could help you?
Only kidding, but you do seem to have it in for the poor Hugo!
Posted on: 29 June 2016 by dave4jazz
Eloise posted:
As Richard said "it's a DAC/digital headphone amp/pre-amp", we like it just the way it is.
Dave
Posted on: 29 June 2016 by Bob Edwards
Gary -
I'm glad you wrote that, because that same question was forming in my head.  I'm in the midst of revamping my system, and a CD5 or progeny seems the way to go.  I've also dabbled with the idea of a used Naim DAC, as it appears to be musically better than the DAC V1.  As the result of some luck on ebay I have a FC2 coming my way, and I might explore other funding sources for a source upgrade (no pun intended).
Posted on: 29 June 2016 by Peter Dinh
Bob Edwards posted:
Is that true that the Naim DAC sounds better than the DAC V1? Anyone confirms?
As just a DAC then yes, the Naim DAC is superior to the DAC-V1.  However, the latter is a much better headphone amp...
Thanks Richard, this makes me feel better as I just got a Naim DAC without auditioning or comparing between the 2 DACs, being too far away from any good Naim dealer. The nearest one is the Gene Rubin, but he no longer does Naim.
Posted on: 29 June 2016 by Dave***t
Eloise posted:
Perhaps with a slightly amended name to reflect that it's similar to a 152, but with a bit more added - a number 20 or so higher, maybe?
Richard -
Thank you for that - I'd be shocked to find otherwise given the price difference!  Time to start saving for one . . .
Posted on: 29 June 2016 by SamC
Just to confirm a Naim DAC is, in SQ terms, very significantly superior to DAC v1. Obviously it is "just" a DAC though, so would need a whole range of extra spending if a headphone amp, pre (especially!), usb/spdf converter and (again, especially) a streamer are wanted.
Also, the naim DAC is upgradable with XPS/555...potentially making it a 3-8k DAC depending on second hand deals. DAC v1 isn't, which can be a useful upgrade itch avoider...
Posted on: 29 June 2016 by MDS
SamC posted:
The nDAC can also be upgraded by the addition of the XP5XS PSU. That is half the price of the XPS2 and in my experience gives about 80% of the XPS2's performance. Worth considering in my view.
Posted on: 01 July 2016 by ellearm
After reading threads in Naim forum, I came across Chord 2 Qute as a very interesting Dac.
Since I dont need headphone amp or pre amp volume, 2qute is very interesting and cheaper than V1.
However Its 3 V output may not be suitable for my Nait2 ?
Posted on: 01 July 2016 by Richard Dane
3V is way too high for a NAIT2 (saying that, even 2V is probably too high, but that's the Redbook standard so that's what Naim comply with) - while the NAIT has higher overload limits, it will mean almost no useable range on the volume control and also the range will fall right where the control is at its weakest with regard to channel balance.
Posted on: 01 July 2016 by Mike-B
+1 Richard,  I've attenuated the input to my Nait-2 by 15dB.   It's moved the volume control position well away from the poor channel balance area.
