Mac Mini settings for audio via USB ?
Posted by: Will99 on 29 June 2016
Apologies for this question which makes me feel like I am clueless -
I am confused about the correct settings in both System Preferences / Sound / Output and Audio Midi Setup. I have had it working fine but today when I played some music it came out of my TV (which I have connected to the MM via HDMI) instead of my hi-if system which I have connected to the MM via USB (DAC-V1).
Not sure what I have done as it now seems to be coming out of the hi-fi system. In Audio Midi Setup I can see the DAC-V1 and I can select this and then select 'Use this device for sound output' so maybe that is all that is needed ? However I am confused because in System Preferences / Sound / Output it also seems to have devices available for sound output but I can't see the DAC-V1 here but I can see my TV (as Type HDMI) along with other options such as Internal Speakers and Soundflower. Also it doesn't seem to make any difference which of these I select as the music still comes out of the hi-fi.
So I'm generally confused about the settings required in both these places on my MM. Any help much appreciated. I also feel dumb because I can't seem to find the answers to this on the search function. Maybe I'll wake up tomorrow and all will be clear ....
