Fraim Set-up
Posted by: Zipperheadbanjo on 01 July 2016
I've found a used fraim for a nice price.. giving it some thought. My gear currently sits on 3 racks of Quadrapsire 4 evo. If I got the fraim, I would put 4 pieces of the gear on the fraim, and the balance on either 1 or 2 racks of quadraspire. The fraim has four levels. Curious what you would those in the know would suggest should go on the fraim, and what should go on the quardraspire.
Currently my gear set up is as follows:
Left Stack:
300 DR Head Unit
empty
Supercap
Center Stack
252
NDX
Empty
300 DR PSU
Right Stack
Hugo TT
Superline
empty
Supercap
Note that my Rega RP10 is mounted on a rega wall bracket.
Any thoughts appreciated!
Posted on: 01 July 2016 by Richard Dane
If you go for it, make sure you read the Fraim build instructions posted in the FAQ.
