USB Not Working Properly
Posted by: SheffieldPete on 02 July 2016
Hi
The USB function on my Unitilite works intermittently. If I don't play music via the USB port for a while it stops working - this to be particularly the case when I change USB sticks. The machine recognises the USB, the list of tracks appears in the display but then all I get is the 'loading...' message when I hit 'play'. If I turn the machine off then on again using the power switch it will work fine.
Any suggestions?
Pete
