Problems after power outage
Posted by: Bodger on 04 July 2016
Last Saturday the mains supply cut out. On return, the system came back and I listened to some vinyl. When I changed to CD I found I got no sound, except when on maximum volume. Just a weak sound. Last time this occurred, the CDS3 had reset to phono output and I changed the settings to DIN and the problem was solved (from oo to O). This time, I checked this first. Still no sound. I also remapped the 552 input sockets and tried the CD input on various other sockets. No sound. Vinyl plays fine via the Superline, 552.
Has anyone else had this issue? Any solutions? I cannot think of anything else to try. Clearly the 552 is working and the CD player is functioning, albeit weakly. Any advice will be appreciated.
Dave
Posted on: 04 July 2016 by Happy Listener
Dave - I've had something similar happen, but managed to sort post a lot of twiddling. Sounds like you are only getting X-talk in the 552, with the CD player producing a signal?
I would, unless you've already tried:
Re-boot 552PS post a rest period and leave for 5 mins
Make sure the 552 volume is turned down
Re-boot the CD PS
Check the DIN output status again - a 555 has this foible.
Map the output for the CD
Check all cabling
Press play and pray...
I know it sounds unlikely but sometimes it seems a re-boot works...
Posted on: 04 July 2016 by Richard Dane
Check the output selection on the CDS3 and the input mapping on the NAC552. They may have been reset.
Posted on: 05 July 2016 by Bodger
Gents, thanks for the tips. I have already done all the above. Also with changing input sockets on the 552, the sysytem has been powered down several times. Overnight Sunday as well.
Each time I have checked the CDS3 output is Din. That the socket mapping is correct on the 552. Green light above the SL din input. I am out of ideas. As I said, last time it was a simple CDS3 reset from phono to DIN output.
Are there any hard resets I can do. Restore to factory settings?
Dave
Is the CDS3 manual still available for download on the Naim site? I can't find it?
Dave
Posted on: 05 July 2016 by Christopher_M
Dave, Mine's in the box, in my shed. Google Naim CDS3 manual. It's there.
Chris
Posted on: 05 July 2016 by tonyi
hifi-manuals .com. All Naim manuals for free
