Connecting a PC to an AV2
Posted by: Steve Cansdale on 05 July 2016
Hi all
How can I connect my computer (via 3.5mm jack) to my AV2 to take advantage of my full system? I have seen a 3.5mm jack to RCA Y Split cable... connect this is into the Analog 4 inputs? Is that the right approach?
Steve
Posted on: 05 July 2016 by Eloise
Yes, the basic answer would be to connect a 3.5mm to 2x RCA cable to Analog 4.  The better option would be a digital output into optical in on the AV2 - this could be achieved direct if your computer already has a optical digital output, or via a USB to SPDIF converter if it doesn't - basic converters only cost a few £10s up or for a high quality converter such as the Gustard U12.
Posted on: 05 July 2016 by Steve Cansdale
Thanks for the quick reply Eloise!
I did think about going optical but both my optical ports are in use now and that would mean I'd have to 'fiddle' with another solution for one of them... I think the RCA would be fine.
Thanks again!
Steve
Posted on: 05 July 2016 by tonym
Another option, if both your optical ports are in use, is to use an optical to co-axial digital convertor. They're inexpensive and work well.
