Nac 52 boards
Posted by: Guenter on 05 July 2016
Hi,
does anybody know what kind of boards - not only phono boards - exist for the Nac 52?
Guenter
The forum FAQ tells all....
Guenter - This is from the original manual around 1992 - not sure if other boards were introduced subsequently.
INPUT AND OUTPUT SPECIFICATIONS
Input 1 options:
NA 522 for moving magnet cartridges . . 2mV/47K Ohms
NA 523S for low output moving coil cartridges .. 100µV/470 Ohms
NA 523K for Karma/Troika type cartridges ..100µV/560 Ohms
NA 523E for medium output moving coil cartridges . .350µV/560 Ohms
NA 526 for line input (fixed) . . 75mV/100K Ohms
NA 528 for line input (variable sensitivity) ... 25 - 350mV/47K Ohms
lnput 2, 3, 4, 5 & 6 (standard - as supplied) ..75mV/100K Ohms
Input 5 & 6 options:
NA 528 (variable) ... 25 - 350mV/47K Ohms
NA 526 (fixed) ... 75mV/100K Ohms
Output 4, 5 & 6 (standard - as supplied) ..... 75mV/600 Ohms
Output 5 & 6 options:
NA 528 (variable) ... 25 - 350mV/600 Ohms
NA 526 (fixed) .. . 75mV/100K Ohms
lnput sensitivities are referenced to 0.775 volts output with the volume at maximum. The inputs will accept input levels 100 times the rated sensitivity before clipping (40db overload margin)
Paqe 14
Hope that helps
Sam
PS. I see Richard beat me to it...
do you have a whole original manual? If yes, can I get a copy as pdf?
Last week I bought a 52 :-)). But without original manual.
Guenter
> Am 05.07.2016 um 18:04 schrieb Naim Audio Forums <alerts@hoop.la>:
Guenter, you should contact Naim customer services by e-mail who should be able to supply a copy of the NAC52 manual in pdf format.
