AV2 Replacement / Upgrade
Posted by: Steve Cansdale on 05 July 2016
I've had an AV2 for an number of years now (and enjoyed it) but I'm looking at moving up to 7.1 and the AV2 (as far as I can see) does not support this. So, two questions, a) is there a replacement for the AV2 that supports 7.1; and b) is there an 'add-on' for the AV2 that will enable it to support 7.1?
Thanks!
Posted on: 05 July 2016 by tonym
The AV2 most certainly does support 7.1! I used mine with this configuration for many years. Check the manual, all knowledge is there.
Posted on: 05 July 2016 by karyboue
Yes thé AV2 supports 7.1 output, even 7.1 analog input.
Posted on: 05 July 2016 by Steve Cansdale
Thanks all! Having RTFM today, I see I missed the 7.1 support... DOH!
