UQ2 Power off
Posted by: Vilya on 13 July 2016
Hello to all
That it's my first post and from Spain so sorry for my english.
I have a UQ2 and i can not power off with the remote, only with the rear on/off switch.
UQ2 always is hot but these is not a real problem, the real problem is that the HDD 500 gb. conected to frontal USB is always on.
Any suggestions?
The USB port isn't really designed for taking a large HDD, rather a USB stick or similar.
The UQ2 only has a proper power switch. Like most Naim kit, it is designed to left powered up at all times. I tend to mute the UQ2 when not using it, only doing a hard power-down if I'm away for more than a day or so.
Muy buenas Vilya,
Wellcome to the forum!!
As Richard said, the UQ2 has no power off button. It must be always on. I guess that a great idea will be to use an external SSD (in fact I am thinking in apply this solution to my Superuniti).
Any comment about the use of a SSD?
...Javi
Javi A. posted:Muy buenas Vilya,
...Javi
Do NOT connect large storage devices to the USB ports of any Naim streamers.
Like the rest of the streamers and the Uniti range, UnitiQute is designed to stream via a wired network (back up via wireless).
...Javi
Well I'm getting rather old and my memory is not what it once was but I am pretty sure that the UQ2 does in fact have a power off switch. Personally, as RIchard says, I never used it and left the UQ2 powered up at all times and on mute on an unused input when I wasn't listening to it.
Power off switch on the rear.
Adam Zielinski posted:Javi A. posted:Muy buenas Vilya,
...Javi
Many thanks to all
I know that Naim streamers are not specifically designed to support HDD but it is a intermediate solution between an usb stick and a NAS system (at least for me) so why no use it?
Javi A,
I have not experience about SSD, with my HDD i had to do a low level format (fat 32) to make it work.
I mean that there is no power switch on the front. The one in the back of the UQ2 is just for switch it off for making connections or changing cables.
I have no experince with SSD on the Naim but from the user point of view it works as a regular HDD, in terms of formating.
...Javi
I leave mine on all the time but have set the display to turn off after only a short period.
If you leave the display on all the time - are the Naim display likely to see screen burn?
