Speaking settings on nVi
Posted by: Consciousmess on 20 July 2016
I'm trying to optimise my nVi and I use the nSYSTEM speakers (nSATs surround, nCENT centre, nSUB) with external large floorstanding front speakers powered by the NAP 300 DR.
The manual is vague, so should the speakers settings be:
Centre - small
Front - large ext
Surround - small
Sub - on
That seems obvious, but wouldn't the deeper tones of voice be detached from the centre speaker by having it set to small? I think that makes the nVi only output limited frequencies to the centre.
Thanks for your help, as I would like to get the basics sorted first before I change 'distance' and 'levels'!
Posted on: 20 July 2016 by Richard Dane
When I ran a full n-system with n-Vi I usually preferred all set to large .  Certainly you should have the n-Cent set to large in this situation.
Posted on: 20 July 2016 by Consciousmess
Ok I will do, cheers.
