Next upgrade suggestions
Posted by: oldneil on 22 July 2016
As above:
1. DR upgrade of the NAP300?
2. Recapping and DR upgrade 8 year old Supercap?
3. Cabling: Upgrade my Hiline/NACA5 to Super Lumina (full loop) and change the Chord C-stream ethernet cabling to something better?
What upgrade first?
Posted on: 22 July 2016 by hungryhalibut
2, 1, 3.
Posted on: 22 July 2016 by Foot tapper
+1
Posted on: 22 July 2016 by Adam Zielinski
1, 2
Skip 3 for now, except for a streaming cable: Chord Tuned Aray range is rather good.
Posted on: 22 July 2016 by Allante93
Hungryhalibut posted:
2, 1, 3.
+2
Posted on: 22 July 2016 by Christopher_M
What is so lacking that it makes you want to upgrade?
Chris
Posted on: 23 July 2016 by oldneil
Adam Zielinski posted:
1, 2
Thanks, I thought all ethenet cables sounds the same. Can you really hear any difference?
And does it mean that I need to change all the ethernet cables ?
Posted on: 23 July 2016 by Adam Zielinski
OLDNEIL - of course you don't have to change the cables. Given the price of some of the more exotic streaming cables an audition is a must. It's easy to hear what they do - choose the one the sounds best to you. Chord actually encourage an extensive home demo and all their dealers should oblige
I use Chord Anthem Tuned Aray cables for all my streamers, except for a UnitiQute which sounds best with a C-Stream. All switch to patch-panel connections, which are used for streaming duties, are C-Stream. The rest of the network is a regular CAT 6, hidden under the floors.
Posted on: 23 July 2016 by hungryhalibut
All of my Hifi part of the network is AudioQuest Cinnamon - router to switch, and switch to NAS and streamer. It gave a good improvement over bog standard el cheapo cable. But this is very much icing on the cake, rather than part of the cake itself.
Posted on: 23 July 2016 by Pcd
I use Audioquest Cinnamon in rthe same configuration as HH a big improvement over el cheapo stuff.
Posted on: 23 July 2016 by Chris Dolan
2, 1, 3 - but try some alternatives at 3
Posted on: 23 July 2016 by Mike-B
Re cables & specific to ethernet:   Chord C-stream is a pretty good performer with SQ when I listened in to a group test,  so try (at home) before you buy.     Also don't get sucked in to Cat-7 "must" be better than the lower Cat numbers,  I can assure you that is not the case.    I had to change from Cat-7 due to an RJ45 plug break,  the Cat-7 (S/FTP) was big bulky & unwieldy & if it was not the cause of the break, it did not help.   I went for a lighter cable that had verified certification of its performance (not many cables have this)  & also that the plug engineering & wire management design made sense to me.  The SQ was a step change for the better & the cable is Cat-6 (UTP).
Posted on: 23 July 2016 by Bart
Christopher_M posted:
Chris
We never know.  It's what we do.  I include me in we of course.
Thanks for your replies!
As I mentioned I already got C-stream (3 lengths), but wonder if Chord Tuned Aray is better from NDS to the switch?
But, first I will recap and DR my Supercap..
oldneil posted:
For an ethernet cable? Past c-stream would be the last upgrade on my list.
