552 Locked
Posted by: NickSeattle on 25 July 2016
Tried powering the whole system down for 90 min.  On reboot, the 552 is muted and set to Aux1.  Mute is supposed to clear after 30 seconds, but does not .   Button pannel does not respond.  Anything I should try before shipping it for repairs?
Thank you.
Nick
Posted on: 25 July 2016 by Mr Happy
I would try shutting it down for 5 minutes and restarting it again as it may have just glitched. Failing that shut down the whole system again and remake all connections. Good luck, fingers crossed
Posted on: 25 July 2016 by NickSeattle
Had to remake the source connections.  I wonder why, but no matter.
Thank you, Mr. Happy!
Posted on: 26 July 2016 by Mr Happy
No problems, Glad it worked
Posted on: 18 September 2016 by NickSeattle
Still experiencing NAC source lock-ups occasionally, along with irritation that System Automation has stopped working with the NAC, but continues to work perfectly with Naim DAC and CD555.  Finally got around to easy test, swapping the RC cable between the NAC and CD -- now the NAC can be controlled, but not the CD.  Tested the suspect Y-cable with headphones and confirmed one leg has become intermittent.  $5 replacement is on its way from Amazon.
Nick
