Uniti internal temperature?
Posted by: Javi A. on 08 August 2016
Hi to all.
Today I was browsing through configuration menus of my superuniti and I discover that in "factory setting" menu the internal temperature of the system is displayed. In my case the internal temp is 42ºC while my room temperature is 26. What value do you have for your unitis units?
As mentioned...
Model   Internal    Room
SU          42          26
...Javi
Posted on: 08 August 2016 by Toe
My superuniti currently 47 deg C after 1 hour playing. Ambient temp mid twenties  & speakers Gb1i.
I think internal temp is around 40 deg C when no music is being played.
Posted on: 08 August 2016 by Adam Zielinski
Standby mode, external case is at around 37-39C.
Posted on: 08 August 2016 by Anto68
My SU internal temperature is 46.  I turn it off at night in summer time
Posted on: 08 August 2016 by Javi A.
Javi A. posted:
Hi to all.
As mentioned...
Model   Internal    Room
SU          42          26
...Javi
I get quite surprised this morning as the int temp without playing music is 46º. It seems that yesterday the air contitioning changes a little bit the system temp. It seems that its normal temp is arround 46ºC.
Posted on: 09 August 2016 by Dan.S
My SU usually sits at around 49C - internal temp. (28C ambient temps) but in its defense the unit is positioned inside a showcase type furniture so not much ventilation I'm afraid.
It goes up to 52-53C during movies (volume 45-50).
