melco n1a
Posted by: Aceone on 09 August 2016
How do you back up or restore to 3.00 version, due to the fact we have updated the melco and we have lost some of our music in the artist folder but the music is still there in the folder when going through the folder option to play
We have been told its a bug and to restore to previous version but cant find it on the melco website
Thank you
Posted on: 09 August 2016 by Bert Schurink
Don't know, but why don't you get your dealer involved...
Posted on: 09 August 2016 by JohnF
There is a 3.11 new fw on the melco site.
Posted on: 09 August 2016 by Aceone
Dealer already involved, and we have updated the melco to 3.11 and the music still hasnt come back under artist so they recommend we install the previous software of 3.00
Posted on: 10 August 2016 by tonym
That's a weird one. I've upgraded my Melco N1Z to 3.11 & there's no problem. Mind you, I always access my music on the folder view.
Posted on: 10 August 2016 by PeterJ
Have you tried updating the Music Database in the N1A settings?
I have had similar problems after I have powered down and powered up the N1A. Albums were not showing in the Artist index but individual tracks were. All was OK after I updated the DB.
Posted on: 10 August 2016 by lowdean
Had the same issue and updating the database once I'd installed 3.11 worked for me.
BTW has anyone tried playing CDs directly from attached disk drive (new feature)?  Wondered about SQ.
Posted on: 10 August 2016 by KRM
tonym posted:
I asked my dealer about the the Melco and they told me they were impressed with the SQ, but we're critical of the need to search using folder view. Apparently with artist and album searches don't work well, even when using the Naim streamer app.
Keith
I use Kazoo / UPnP Server (because I like to control from both my Mac and iOS devices).  Search takes geological timescales!
Posted on: 10 August 2016 by Jonas Olofsson
FW 3.10 had a bug and shouldn't be used. FW 3.11 replaces that one and are flawless.
If you actually use 3.10 now, ask your dealer how to install and reinstall your music with 3.11.
He should know how to do that, if not, contact Melco direct.
//Jonas
