Sky HD / PS3 via NDX/nDAC
Posted by: Dingding on 10 July 2011
I have a problem when watching sky HD and blue ray disc on my PS3 when using the NDX.
My sky is connected via coax & my PS3 is connected via optical in the back on my NDX they work perfectly but as soon as I switch to a HD channel I just get very loud digital sound. I have tried all settings but they just won't play ball.  Any one got any ideas?
I love a idea of having all controls for the system in one place so I don't fancy going back to analogue .
Thanks in advance guys.
Posted on: 10 July 2011 by Frizzlefry
You need to change the output settings in both your Sky box and PS3.
I don't have Sky, so if I remember right; Go to settings, then sound page. You need to change the output from Dolby Digital to PCM/Stereo.
Same with the PS3, under sound settings, set output as optical, but do not select DD or DTS, just highlight the stereo options.
At the minute you're sending a surround bitstream to a stereo DAC, which it cannot decode, hence the noise.
Posted on: 10 July 2011 by Dingding
Many thanks for your reply, I have just checked my setting and that's what they are both set too, sadly still not working.
Posted on: 10 July 2011 by Hook
Hi Dingding -
Assuming you have those digital inputs enabled on the NDX, they should be able to decode a PCM signal up to 24/192 from your PS3 and cable box.
Might be worth a try changing the NDX digital input's "Unstable source" setting to "yes".
Hook
Hi Hook,  thanks for your reply. That too sadly still no luck.
Posted on: 10 July 2011 by murkku
PS3 has an option "BD/DVD Audio Format (Optical)" under "Video Settings".
That should be set as "Linear PCM" as otherwise PS3 sends audio in DD/DTS format and that will not fly with NDX/nDAC.
