iLinx contolling NS01
Posted by: Siy on 12 July 2011
Hi all,
I have a Naimnet system with digilinx controlling multiple zones. I now use iLinx to control it, but find that recently it has been connecting ok, operating fine, then just freezing after a while . Any obvious reasons or anyone else with this issue?
Posted on: 12 July 2011 by Phil Harris
Hi,
There's no inherent iLinX issue that causes it to "drop out" that I am aware of - is your iDevice still connected to the network at the time (i.e. is it the App that is dropping or is it the device itself)?
Phil
Posted on: 12 July 2011 by Siy
Thanks for the quick reply... the device is not dropping out.... teh app is always running and on the iphone/ipad... basically, If iI havent used the system for a bit and try, it will turn on...I can change tracks/albums etc a few times.. then it just freezes. If I then switch it off and reload the app, then it connects again.
Exactly same thing happens with my pronto (which controls digilinx also).... The devices both always stay switched on, and running the app/control page
If I use a touchscreen however, I can use the system normally
