Synology NAS, help needed in reseting the admin password
Posted by: kiba on 10 August 2016
Can anyone help me with a basic step by step guide in resetting the pasword on a Synology  NAS to admin/blank, including the pitfalls (like reestablishing The ip adress).  Have read the Synology forum, but still not seen any clear guidlines, but a lot of confusions. Have had good help from Naim forum before, so my best hope here
I tried to logon to my synology NAS, but the usual admin with empty password is not working any more. I use auto update, and have just read that a synology update has removed this "option".
I have a minimum of network knowledge, and would like to be prepared, before  just jumping into "hit the reset bottum".
I use my NAS with 272+555, 300 and US,  but had set it up a long time ago
Posted on: 10 August 2016 by Bananahead
Why not use the built in password reset function ..
Posted on: 11 August 2016 by kiba
Hi, i know, press nas reset buttom, but what about my network settings, according to synology,     The ip adrees will be default, how can i establish this one again, and are tjere other pitfalls ?
Posted on: 11 August 2016 by Mike-B
I've never heard of this problem & wonder what did you do to prevent it working as it was before,  A reset & start again is the best way forward.
Press the reset button on the NAS until you hear the beep sound.    Then start over as a new install.   Password will be default "blank",  reset guest account to disabled & set yourself as administrator & then (please) set your own password.
Next advice is don't mess around with IP addresses,  if you get it wrong (& thats easy to do) its a bad place to be & I suspect that might be something thats got you in your password problem.    Please reset all your system to DHCP,  the wireless hub/router is the DHCP manager & it is a real expert at correctly setting up your network:  Set every component on the system to DHCP first ,  then switch the whole system off, leave it off for 5 minutes & then switch on in sequence;   router first & let it complete its startup process,  then start NAS & after its completed the 272 & then whatever else makes up the system.
Posted on: 11 August 2016 by Bananahead
Again.
When you try logging onto the NAS you get the USER/PASSWORD screen that has a "I Forgot my password" option. Have you tried that?
I don't think that you need to reset your NAS.
Posted on: 11 August 2016 by Pcd
I had this with my 212j did a reset the default as password was ADMIN when this was done all worked OK.
Hi, thanks for your answer.
The situation root cause is, that I did not create an admin password in the first place, I left it blank as left by synology. But an update 5.2-5644,  20151117, by synology, do not allow this any longer. As i run auto update, I was locked out by synology.  I know of the reset button, but reading in the synology forum, there are different not so good experinces. i have not changed any default settings to my knowledge, so yes it's maybe not so complicated, I can press reset, and hope that every thing works  (read US can see NAS) and then I can log into the NAS with admin/ blank, and after this make a admin pasword of my own
Hi, all well
I hit the reset button, made new password, and every thing is working,
thank you all for your replies, the forum worked again, and fast
Glad all is sorted it can be extremely frustrating at times.
Posted on: 12 August 2016 by Bart
Pcd posted:
Not to be too picky . . . BUT . . . the obvious solution was to do that reset button process.  Only frustrating if you do a lot of hand-wringing.  Sure, there somewhere online is someone having posted, "I pushed that reset button and my nas exploded and burnt down my home," but one must filter such posts with a little common sense.
Posted on: 12 August 2016 by CSI_Basel
Bart posted:
I'm going to search for that post!
