What do you like on Archive.org?
Posted by: Skip on 13 August 2016
https://archive.org/details/etree
Been listening to the Grateful Dead, Little Feat, the Radiators, Grace Potter, all free and sounds variable but pretty good for live music.   The price is right.
They even have Stanton Moore, Sarah Jarosz, Alabama Shakes, Bela Fleck and many others.
All free. Check it out. I just plug my MacBook Pro into my Halide DAC HD cable, and into the pre amp.
You can look under each section and see the most popular by the number of downloads.
Great variety from old to new.   The top Little Feat is almost as good as anything I have heard.  I can find the Dead concerts I went to 30 years ago.
This is the Little Feat for example.  This is a live radio show from 1974!
https://archive.org/details/lf1974-09-19.shnf
Pretty amazing resource.  I hope you can get it from outside the US.
If you find anything you particularly like, please let us know.
sc
Posted on: 15 August 2016 by Pev
Lots of Deadhead Archive fans in the UK - we can get it no problem. Wolfgang's Vault is another similar resource. The main problem I have is lack of sufficient life expectancy to listen to all the wonderful music that is available.
