Muso issue post update
Posted by: Skip on 15 August 2016
I just upgraded my Muso to the new software/firmware this weekend.
Tonight, for the third time so far, the Muso switches itself to Bluetooth.  We keep it set to Digital because that is where the TV goes.
We are nowhere near the remote.
Has this happened to anybody else?  What could be the cause?
Posted on: 16 August 2016 by jon h
not noted here on two. Are any devices paired with bluetooth? Might they be chirping on BT and making the muso switch?
Posted on: 16 August 2016 by Skip
My hearing aids are paired with my phone.  I will turn off the BT on my other devices and see.
Posted on: 17 August 2016 by Skip
Turning off the Bluetooth on our laptops, which had not been paired with anything, seems to have solved the problem for now.    If I have more to report, I will post it here.
Thanks for the easy fix.
