DAC-V1 as a seperate DAC to Rega Apollo-R CD Player...
Posted by: VinBob on 18 August 2016
Hello all and fellow DAC-V1 owners!
I have a quick question which I was hoping someone could kindly help with on my DAC-V1. I thought I would use it as separate dedicated DAC with my Rega Apollo-R CD player as the transport, and the display on the DAC-V1 is giving a 'Cannot Reclock' message. I tried this with what I assumed was a lesser CD player (Sony DVP-S7700) and using the same high quality Transparent 75 Ohm coax cable to the DAC-V1 S/PDIF input, I don't get the same error message?! ![]()
Has anyone experienced this with the same combo and if so, is it something that needs to or can be fixed via the Rega CD player, or is it just a comparability issue that I will just have to live with. Looking for some thoughts/feedback as to whether there is anything that can be done or just leave it be and simply use the internal Apollo-R DAC which presumably, shouldn't sound any worse than the DAC-V1 as they use the same Wolfson chipset I believe ...
Vin.
