NAP200 Buzz
Posted by: Mark Carwardine on 21 August 2016
I hear a buzz coming from my (2014) NAP 200 when I turn it on, the buzz does not come from the speakers but the unit itself. Is this normal?
Thanks,
Mark
Posted on: 21 August 2016 by MarkJH
Apres moi, Le deluge....
Posted on: 21 August 2016 by Mr Happy
Yes it is normal, assuming its more of a hum than a buzz. Its the transformer. If you do a search there are many posts on the subject.
Posted on: 21 August 2016 by hungryhalibut
Mr Happy posted:
Hundreds, if not thousands. The search facility is a wonderful thing.
Posted on: 21 August 2016 by Huge
is it always the same or does it vary from time to time?
If it's constant and unvarying, then that's usually due to the transformer itself.
If it varies, that can be an indicator that the waveform of the mains electricity supply is distorted.
This can either be because a distorted waveform is being supplied to your property, or because of other electrical devices inside your house.
Posted on: 22 August 2016 by Claus-Thoegersen
Huge posted:
Normally I have no hum but a few days ago all amps and power supplies were quietly humming away, but now they are quiet again, I wonder what happened somewhere else.
Posted on: 22 August 2016 by Sounsfaber
My xps has been humming for 15 years
Posted on: 23 August 2016 by Huge
You'd have thought it'd have learnt the tune by now!
