Copy LPs ?
Posted by: al9315 on 22 August 2016
Just seen an article on " Korg DS-DAC-10R " most of which I really have to admit to not understanding. It does not appear to be readily available, but I am sure there are other gadgets out there ?!
The "Korg" ad states that one gets software with it which allows copying and that the "Korg" also has it's own phono stage - so presumably no need for PC to be brought into same room as Hi-Fi ? - which would be good.
" The DS-DAC-10R supports the 5.6 MHz and 2.8 MHz DSD format—for playback and recording—as well as PCM formats up to 192 kHz/24-bit, and has a built-in phono equaliser compatible with the standard RIAA curve used when cutting records, as well as five other equalisation curves. "
I am half thinking about "digitising" my LPs on to my QNAP and just streaming everything - have already done CDs - and pretty happy with the current setup.
1. Is there any reasonably easy way to copy LPs and retain good quality sound ? ( Korg ?)
2. Where does one find a tutorial or other means to try to learn about some of the "lingo" to make a sensible choice - DSM PCM 5.6MHz & 2.8MHz DSD + various other terminology which really means nothing to me?
I am assuming IF one decided to go down this route that some sort of quality DAC will be required and perhaps some software - does it just get plugged into the output of a pre-amp - then presumably DAC --> PC ........ ?
There seems to be a multitude of standards? - I recently downloaded a new album - it reads on my tablet as 48kHz 2304kb/s - not sure if this is good or bad - but it sounds pretty good to my old ears - another one reads 96kHz 4608kb/s !?
It crossed my mind to just buy a DVD recorder and connect it to pre-amp and play LP onto DVD then upload to PC the repeat the process (1000 time or more?) - but this obviously limits one to 44kHz as CD
I think even I realise the higher the number the theoretically better the sound, but would not wish to contemplate doing this big exercise without trying to get it right from LP (1) !
I have had a search through the forum posts, but can't find any recent opinions
Any advice most welcome
Al
