Combination Fraim and Fraim Lite
Posted by: MartinKocurek on 27 August 2016
I am wondering if I cab combine in the same rack levels from Fraim Lite and Fraim.
I am planning to add additional level, currently I have Fraim lite but new one I would buy Fraim for my NDX .
But not sure if it will fit on Fraim lite lower levels..
Do you have experiences?
Posted on: 27 August 2016 by hungryhalibut
Yes, you can do that.
Posted on: 27 August 2016 by MartinKocurek
Thank you.
The pitty is that delivery time to Czech Rep. is 3 months :-(
Moderated post:  I've edited your post. Please abide by forum rules, thanks.
Posted on: 27 August 2016 by yeti42
I started with Fraim Lite, then bought one level of full fat Fraim. Initially for under the CDX2 but eventually it found its way to under the superline where it stayed. No problems mixing the two. After the improvement of the first ffFraim shelf I bought 2 bases and extra balls, cups and glass along with a medium shelf. Swapping bits around  this gave me fffraim under all the Naim boxes and doubled fraim lite base shelves which I left empty. They've scince been filled and the upper bases changed for a fffraim shelf on each. I now have lite shelves spiked to the floor with fffraim from there on up for both stacks except for the turntable, Nad tuner and a tivo on lite. I regret not buying full fraim in the first pace but balked at the cost.
