Technical xps vs 555 on 272
Posted by: Emre on 27 August 2016
I am considering/saving/dreaming/ planing/hopping to add a Naim PS To my 272/300DR set up, I read everything on forum, the general consensus is 555PS is better but at a cost, or even can be considered little too much for 272
My question is what do I get when I buy an xps vs 555ps? how a PS is effecting the SQ and what am I getting in technical terms in xps vs 555? What is causing the price difference?
How xps vs 555 works?
Can somebody explain it to a non engenier like me?
Also having a 300dr vs 250dr will I get more benefit out of 555?
Do you think 555 will be future prof for a possible 372?
555 is a great investment, I like to to know more, audition them in my house is impossible.?
Will I improve the streamer/dac or pre or both?
I really appreciate your valuable inputs
Posted on: 27 August 2016 by Adam Zielinski
XPS is a turbo for your car's engine.
555 DR is a turbo, and a compressor and than some more....
Posted on: 27 August 2016 by Richieroo
I add a 555ps to my 272 it made huge difference. ...
Posted on: 27 August 2016 by greekspec2
Emre posted:
I have the same system as you except Sopra 3's and I asked the exact questions to the North American Naim brand manager and this is what he told me...
The XPS DR is indeed the natural partner for the 272 and the one that will give the best overall balance. PS555 will bring a little more (more details for example) but, then the 272 will be the weak link…I recommend the XPS DR,
The 272, XPS DR is great with a 300DR, this is what we used when we did the dealer’s introduction of the Sopra line.
 You are right for the 300, Focal guys love this amp. They do not like the 500… too much Flat Earth as the brits say.
They have done the final check with Statement for sure… it is now our reference….
Posted on: 27 August 2016 by Innocent Bystander
Adam Zielinski posted:
A turbo AND a compressor. That's interesting! So its a biturbo like the wonderful diesel Saab had introduced just before going bust?
presumably, though, it doesn't compress the sound, just makes it go faster...
Posted on: 27 August 2016 by Emre
 anybody knows how they work and how they will do a difference?
Is the PS and upgrade for streamer or pre? Or both?
For example will my cd2x or a future turntable benefit from 555 instead of xps?
Posted on: 28 August 2016 by Adam Zielinski
Innocent Bystander posted:
Just faster, with more details
Emre posted:
Do check the manual - I'm sure it elaborates on which circuitry is oowered by an external PSU.
As to your second question: you can attach XPS or 555PS only to one component. So CDX2 if running in an analogue out, will need an own dedicated PSU.
Posted on: 28 August 2016 by ChrisSU
Emre posted:
On a 272, the external PS powers everything. How much benefit this brings to the analogue side I couldn't say, but with an XPS connected, the 272 no longer uses it's own power lead.
