Optical or Coax?
Posted by: ChrisG on 28 August 2016
Hi
Just setting up my UnitiQute2, I'm also using a Sonos Connect for Spotify and my existing music library, (when listening multiform) is it best to use an optical or coax cable between the Qute and Sonos, I have a QED Performance Graphite optical cable at present but the connector doesn't seem too positive't in the socket both at the Qute and Sonos end?
Are there any recommendations, not too expensive, for either optical or coax cable that fit and perform well?
Best
Chris
