Extension lead required
Posted by: MRJ 1960 on 31 August 2016
i have recently had to move my Uniti2 and Neat Iotas into the dining room. This in itself is not an issue, but what is is that I have to power the Uniti2 from another room via an extension cable passed through a wall. Due to factors that cannot be changed for the foreseeable future I will not be able to run a spur.
So the question - thoughts on a good quality extension lead (I reside in the UK, so kit available there only please). Side (maybe silly, sorry mechanical engineer not a sparky) question - is there any point in installing a Powerline if it is fed from an extension cable?
Many thanks
Posted on: 31 August 2016 by joerand
MRJ 1960 posted:
You ought to be able to readily answer that one yourself.
As far as the extension it would be helpful to know how long a distance. If relatively short then a couple of Tibias might do the trick.
Posted on: 01 September 2016 by Mike-B
Is there any point in a PowerLine on the end of an extension,  its the same question as is there any point of one on the end of a 2.5mm UK ring main.
Depending on the length you need - I would just buy some decent cable such as Belden 19364 (from MCRU) plus an MK 13a ToughPlug & a socket strip with as many outlets as you need & make your own.      If you can do it with a 2m ready made extension, a Tacima CS947 is an excellent lead.
(Joerand's reference to "Tibia's" is a USA brand (& not available in UK)
Posted on: 01 September 2016 by Simon-in-Suffolk
Mike - I use Powerlines on the end of a home made RFI rejection braided mains extension - and they absolutely provide a positive benefit to most - but not all - of my Naim components. In my experience mains quality isn't necessarily all about cross sectional diameter of the the mains distribution wiring - cross sectional wiring diameter I guess gives a better indication of regulation if one excludes PowerFactor however the plugs and sockets have a significant impact as well along with how one sets up the safety earth arrangement in your house. I am an advocate of TT as opposed to PME earthing systems so as to reduce mains borne noise - but I am fortunate that I could have my property professionally converted.
Simon
Simon,  I am an electrical engineer & I'm not disagreeing at all with your post,  but the OP was asking what to do with a temporary extension lead set up.   I was trying to advise on a sensible way to do this & IMO Powerlines are surplus to requirements ITR.
Posted on: 01 September 2016 by James L
Funny things those shielded mains cables. I always "felt" they had a negative impact.
This might seem simplistic and a very flawed theory but if there is any noise that is radiating from the cable, let it out I say before it gets to the distro strip...!
Posted on: 01 September 2016 by hungryhalibut
Might it work to buy some decent mains lead and put a 13amp socket on one end and an IEC female plug on the other, and not use the Naim lead at all. There would be fewer connections involved.
Posted on: 01 September 2016 by james n
Hungryhalibut posted:
Good idea. Just make the lead up yourself (if you can wire a mains plug then you can wire and IEC plug). No need for anything fancy. Just get some mains cable from B&Q of the right length and you'll be sorted.
Posted on: 01 September 2016 by Pcd
As Mike-B, I used the MCRU supplied cable kit to make up a 4 metre lead to supply a Unitilite in my bedroom system this as recommended by the dealer as opposed to using standard extension leads works a treat.
