Hi and help or pointers needed re noise feed on uniti-qute2
Posted by: Nuno22gp on 08 September 2016
Hi everyone.
My entry into a decent sound system consists of the following:
Naim Uniti qute2
Sonus Faber B
REL T9i
To the qute the following are hooked up:
Apple TV via fiber optic digital cable
samsung tv via fiber optic digital cable
cable tv via rca cable
internet via ethernet
Here's where I need help. If only all was well... Everything sounds great except Apple TV or if attempting to play anything off the tv´s apps, such as netflix. When doing this, there is no sound but a terrible "feed" noise. Keep in mind however that sound from the tv is perfect - using the same optic cable, the same input on the qute- the moment an app is started however - thumppppppppppp. Apple TV is Ethernet wired, TV is wifi. Just doesn't make sense (to me) and is likely something obvious but hey, it's got me licked.
Sound familiar to anyone? Thanks a stack.
Posted on: 08 September 2016 by Dave***t
The digital out from the offending sources isn't set to the wrong kind of signal, is it? (PCM vs something else, the UQ manual should help). Think I remember a similar issue at first.
Posted on: 08 September 2016 by Mike-B
Have you searched the www about Netflix crashing ???  It does answer the line noise question but I'm asking (only) as I know very little about it other than I know someone who uses Apple & has problems & he says its global.
Posted on: 08 September 2016 by dayjay
I don't know the Apple TV but I did have the same issue with the output from a cheap streamer - as Dave suggested above it was a case of changing the output from the source and all was good
Posted on: 09 September 2016 by Richard Dane
The Qute is a 2 channel PCM DAC so you need to set the output of any attached digital AV kit to force PCM 2 Channel, otherwise whenever a multichannel source is played you just get horrible noise.
Posted on: 09 September 2016 by Nuno22gp
Thanks guys.
To really confuse the crap out of everything, after reading your suggestions, I changed the digital output out of the TV to PCM and  now everything is ok, including the Apple TV, although I did not touch the apple settings. Thinking that something was amiss, I changed the tv settings back to Linear and still the sound is ok. No idea what happened but as all is ok now I'm happy.
#gremlins...
Richard Dane posted:
Thank you Richard. This is what I did and everything is a-ok.
