Naim SBL MKII - dedicated feet
Posted by: Naimark on 12 September 2016
Hello everyone,
I would like to change my feet on SBLs avoiding spikes or something like this.
In fact I would to bring ou low frequencies too controlled and "light" in my opinion.
The speakers are close to the rear wall and I have ultimated the setup with silicone, new gasket kit and so on...
Any advice for that?
Thanks in advance,
mark
Hi, Try them closer together first if you can, Mark.
Chris
The problem is that they are not the original ones and probably they don't match with my SBLs.
They are very similar to the feet represented here below.
I'm half wondering if a set Naim M8 (check first) spikes would solve it.
C.
Order some new spikes from Naim, and get some floor protectors to go beneath the spikes. This will give the optimum sound.
Spikes into sacrificial 40 cm x 40 cm wood blocks should be fine.
+1 for spikes here, screwed in as much as possible with the speakers perfectly level and hard against the wall. Some like a tiny bit of toe in, others swear that they need to be parallel to the wall. If you use the wooden blocks as David suggests they are easily moved to find the best location.
my favourite 'speakers, enjoy!
Stu
These are the floor protectors I was thinking of. They are made by Quadraspire and cost £24 for four. Naim chips are doubtless better, but they are ever so expensive.
Anyone tried Soundcare Superspikes under their SBL's?
Not me. I read all the SBL related posts written by JV. He was pretty adamant that Naim spikes should be used directly into the floor. For any SBL fans they are essential reading in my view. Nice to have those insights into both their design and set up details.
Nothing wrong with experimenting, I just happen to belive he knew a bit more about this than me...
Stu
How did this end?
C.
Hello!
I switched to legendary SBL two years ago. Caught a fresh pair by a dealer who forgot them. Installed at home I was quite disappointed. I tried everything again and again. Gasket, grill, position. My final solution? Substitute the standard spikes for RDC cones - you get a complete new speaker!!! It's unbelievable! Now I know SBLs real potential and I Love it. Wouldn't change a thing. It's fast, livelike, crisp with a good bass. Yes, bass. SBL can go deep!
Matze
Nac, Nap 202/200, Nd5xs, Hiline, non-Naim psu, SBL,Naca 5, Rega P9, Grado Platinum
