If posts were sausages ----
Posted by: Adam Meredith on 18 September 2016
-- and the forum was a plate.
Would it be possible to have too many sausages on the plate?
I think it odd that no one (else) has asked this.
Posted on: 18 September 2016 by Donuk
Nothing that a prick with a fork wouldn't remedy........
Posted on: 18 September 2016 by Tony Lockhart
I don't eat meat, otherwise a sausage post might have been on the tip of my tongue.
Posted on: 18 September 2016 by Simon-in-Suffolk
Donuk posted:
Posted on: 18 September 2016 by GraemeH
You are mashing your tenses Adam.
'If the forum were a plate...' or (if was) '...would it have been possible to have too many sausages on the plate.'
Also, one man's 'too many' is another man's 'not enough...or just right'.
Posted on: 18 September 2016 by sjbabbey
Ooh, bangers and mash. Lovely!
Posted on: 18 September 2016 by Willy
Fences would be much less effective.
Willy.
Posted on: 18 September 2016 by hungryhalibut
Well, it depends on the damping factor of the sausages.
Posted on: 18 September 2016 by dayjay
I've had about two hours sleep after an airport run for Mrs Dayjay and I really can't get my head around what is going on here.  The only bit that made sense was the
Posted on: 18 September 2016 by winkyincanada
If you can't (b)eat them, join them....
Posted on: 18 September 2016 by TOBYJUG
Posted on: 18 September 2016 by Huwge
Adam Meredith posted:
Only if Berlin Frites were (was) the condiment
TOBYJUG posted:
I suspect he's thick skinned enough to cope with this sort of jibe...
Posted on: 18 September 2016 by tonym
...all the fences would fall down.
Posted on: 18 September 2016 by JamieWednesday
One can never have too many sausages on the plate.
Posted on: 18 September 2016 by joerand
If Ifs and Ands were pots and pans,
’Twould cure the tinker's cares:
if ladies did not carry fans,
They’d give themselves no airs:
If down the starry skies should fall,
The starlings would be cheap:
If Belles talk'd reason at a ball,
The band might go to sleep.
Posted on: 19 September 2016 by Salmon Dave
GraemeH posted:
He wasn't, actually.
If posts (plural) were - past simple plural, and the forum (singular) was - past simple singular.
He could have used the subjunctive ('were' in both cases) - but that would have been a change of mood, not tense.
Posted on: 19 September 2016 by GraemeH
Salmon Dave posted:
GraemeH posted:
Oops!
Posted on: 19 September 2016 by stuart.ashen
I know Adam knows his onions but this is just riding the gravy train...
Posted on: 16 October 2016 by ekfc63
Toulouse are my fave.
Posted on: 16 October 2016 by BigH47
No they should be tight!
Posted on: 16 October 2016 by Christopher_M
Sausage in cider.
C.
Posted on: 16 October 2016 by Innocent Bystander
No.
if there were too many they'd simply fall off the plate.
Posted on: 17 October 2016 by Dozey
If that were the case my Labrador would be a member.
Posted on: 17 October 2016 by Huge
Just get a bigger plate.
Analogous to too many post on the forum - just get a bigger server!
Then get them to work in a restaurant and serve out the sausages on smaller plates!
Problem solved.
Posted on: 26 October 2016 by yeti42
When do they count as consumed? When read, when threads are locked, never? Though some undoubtedly start out as andouillette they don't all befall the fate of sausages once eaten.
