Jango Radio
Posted by: Beachcomber on 22 September 2016
For a while now I have been using Jango Radio. For those that don't know of it, it is an excellent resource for finding music that you might like. It isn't a radio station in the normal sense (where you just listen to what they decide to put out) - you (to an extent) choose what you want to listen to. There is quite a lot there, somewhat curated.
I'd like to be able to listen to it using my NDX - but I have not been able to find a way of doing so (short of attaching a PC or similar to the NDX by the PC's audio output). Does anyone know of a way to get the NDX to access Jango directly? or some other device to pick up music from tinternet to play through the NDX (or presumably just straight through to the pre-amp)?
Steve
