Naim App and iOS 10 - playlists
Posted by: Glyn on 24 September 2016
Apologies if this has been covered elsewhere.
Following adding iOS 10 to my iPhone I can no longer reorder playlists (with a long press on a track and moving it up/down) created in the Naim App (v4.8).  I'm certain I could do it using iOS9.x and I don't think anything else has changed.
Has anybody else come across this?
Posted on: 24 September 2016 by Adam Zielinski
Have a look at this thread. Seems related, if not exactly the same.
https://forums.naimaudio.com/to...eamer-not-responding
Posted on: 26 September 2016 by Glyn
That may be connected but is a different issue.
Can anyone with App based playlists confirm if they can still move tracks up and down to change the playing order with iOS 10 on their iPhone/iPad?
Posted on: 26 September 2016 by ChrisSU
Other users have found the same issue and reported it to Naim, so it's now a known issue which they should be able to fix via an app update. Personally I prefer to create playlists on my server which can then be viewed and played on the Naim app: this gets round the issue for playlists, but not, of course, for play queues.
