Mu-so and QB sound tweaking tips....
Posted by: NIC NAP on 01 October 2016
Having owned both units ( love em ) here are a few tips. Firstly, try not use the supplied mains cables. Using better quality mains cables made a significant improvement to both mine. Do not go too expensive, used a couple of £50 ish upgraded figure of eight mains cables which tightened the sound up no end. Next, the Mu-so benefits from that old tip, Blutak. Again does wonders to tighten the bass. Strangely the QB sounds best without Blutak. Next, when listening make sure you remove those speaker front covers !. Particularly on the Mu-so the cover is not fully acoustically transparent, too much plastic in the design on the rear frame. Another tip, found both sound best when placed on glass tables. Play around with room positions as well as even a small difference can make a real improvement. Lastly, a plea to Naim, can a firmware update be considered in order that bass and treble can be altered independently rather that the off/on loudness control. Happy tweaking.....
