Mu-so + QB multiroom with Spotify? Does it work?
Posted by: Hemmendorff on 05 October 2016
Hi, i have a mu-so in my living room, and was planning to add a Qb for my bedroom. So i went to my local naim retailer with the intent of getting one. But when i asked if multiroom worked with Spotify they said "No, due to licensing blaha it can't be played on two devices at once". I found some old threads on this forum suggesting the same.
But according to naim's website, it should work (by using one as a master, which is streaming to the other, bypassing spotify's one-device-limit, as i understand it).
"To play audio from one Mu-so to another, select material for playback from either the Airplay, Spotify, TIDAL, iRadio, or UPnP inputs and touch the Naim Audio App multiroom icon" - https://www.naimaudio.com/conn...mu-so-hints-and-tips
"Version 4.3 will enable [...] Spotify Connect in multiroom mode and benefit from a host of minor bug fixes" - https://www.naimaudio.com/news...o-streaming-products
Someone must know if this really works?
