50 or 75 Ohm
Posted by: cat345 on 05 October 2016
I want to remove the BNC adaptors connected to the phono inputs of my NAC102 and replace them with BNC connectors. Do I need the 50 Ohm or the 75 Ohm type of connector?
Thanks!
Posted on: 05 October 2016 by Adam Meredith
50 Ohm.
What is the tonearm lead? These can be a bugger to fit.
Posted on: 05 October 2016 by Richard Dane
Adam Meredith posted:
50 Ohm.
If your dealer can do a decent job fitting them then get them to do it...
Posted on: 05 October 2016 by cat345
50 Ohm.
It is the original lead from the Aphason HR-100s tonearm and it has rca connectors.
Posted on: 05 October 2016 by Mulberry
That is a fine tonearm, Cat. A friend of mine has the original Sonata/Atlas/HR-100 setup and very much enjoys it.
Mulberry posted:
Thanks! I have used it for years with my Nait2 which has rca phono inputs but now I'd like to try it with the 102.
Posted on: 12 October 2016 by cat345
Richard Dane posted:
50 Ohm.
Thanks Adam and Richard. My tonearm is just back from the dealer who fitted 50 Ohm terminals and it was worth the hassle!
