Bluetooth transmitter
Posted by: solwisesteve on 06 October 2016
Sorry but I didn't know if this is a Hi-Fi Corner thing or a Streaming thing.
Second apology for even mentioning the work Blutetooth on a H-Fi forum!
Anyway, SWMBO wants some music in the kitchen. At the moment she simply turns up the volume in the living room where the Naim is setup but then it's a bit too loud in the living room and doesn't really sound that great in the kitchen. So I had the crazy idea of installing a Bluetooth speaker in the kitchen! Okay it won't exactly be Hi-Fi but perfectly acceptable for a kitchen ;-)
So after wasting and hour with the NDX before I twigged the bluetooth on the NDX is for INPUT only I had a quick conversation with Phil who suggested I put a bluetooth transmitter on the digital output on the NDX. To that end I have just take delivery of a cheapo digital in (coax) to bluetooth transmitter which I'm itching to have a play with tonight.
Anyway I was wondering has anybody done this before? Any pointers or comments? Can anyone suggest a good bluetooth transmitter? The cheap one from ebay is okay for proof of concept but are there better quality transmitters?
Thanks for any feedback.
PS did consider a MuSo (or similar) but then found out a) You MUST use a phone to control the MuSo (that's a no-no for me and the wife) b) it forgets to work as a multi-room device once switched off so you have to reconfigure it when you switch it back on (why? Why not remember the last setting?).
