Is there a good way to edit FLAC /song metadata on my iDevice?
Posted by: Klout10 on 08 October 2016
Hence the title of this topic ...
Any suggestions are welcome!
Many regards, Michel
I'm not aware of any way to do this, other than using N-Serve if you have a Naim server - presumably the new Core will retain this ability. No use to you if you have a regular NAS/server though.
Meta-Music Tag Editor, Audio Metadata; I use this program in my mac and is good enough.
Kacper
ChrisSU posted:I'm not aware of any way to do this, other than using N-Serve if you have a Naim server - presumably the new Core will retain this ability. No use to you if you have a regular NAS/server though.
Thankx Chris, I already thought that ![]()
Kacper posted:Meta-Music Tag Editor, Audio Metadata; I use this program in my mac and is good enough.
Kacper
Thank you for your reply Kacper, I'm really looking into an app for use on e.g. an iPad, not a MAC ...
What I do - which doesn't resolve the question - is whenever I find an error I make a note of it on my iPad's Notes app. This would include poor covers or any incorrect genres. Then, when I use the Windows laptop, which is generally when I rip a new CD, I sort out the metadata from the Notes list, using dbpoweramp.
Hungryhalibut posted:What I do - which doesn't resolve the question - is whenever I find an error I make a note of it on my iPad's Notes app. This would include poor covers or any incorrect genres. Then, when I use the Windows laptop, which is generally when I rip a new CD, I sort out the metadata from the Notes list, using dbpoweramp.
That is indeed a good idea. Currently, I don't have a Windows laptop available (hence the question) but this should be a good way to deal with this ...
